Automatic weld lines to drawings
We need to get weld lines from 3d model to show up on the drawings. Adding them manually by using "insert weld line" is too much work. (Adding them to every cut or detail).
We need an option to show the welds that are inserted to 3d model by "line of weld" command automatically on drawings.
When I generate drawings I see no weld line, only labels. But requirement is to show weld lines also.
Drawing Style manager has  "Weld line Object Presentation" but it seems do do nothing.
https://forums.autodesk.com/t5/advance-steel-forum/weld-line-to-show-up-on-drawings/m-p/7412653#M132...
2 Kommentare
Pleas add this feature, a lot of customers need it.
bigcarl5000kg
Please add the weld lines as in Autocad Mechanical ...
Idee einsenden
