AUTO CONNECT OBJECTS COLLIDING WITH COPIED BOLT
While manually copying bolts, bolt objects maintain original length but collide with plates and profiles in new position and no new hole is created. It would be useful to have a function which auto connects selected objects where a bolt is colliding with an object.
2 Kommentare
IR8ASU1
Schlemar
Do You use Autocad - Copy?
With Advance Copy it will work fine. After copying the holes are created and the Bolt Length is new defined.
Idee einsenden
