Per attached screen pic: the view on the left is a plate detailed with customized dwg style, the one on the right is detailed using the default Advance Steel dwg style Assembly Plate.
When modified, dwg style is dimensioning all holes proper way, not just partially.
Also-the detail title includes length: 2-106P3- PL1/2x6x1'-0" -This is an AISC requirement for plate name.
It will be good if this dwg style is the default dwg style offered by Advance Steel.
Also-very often similar dwg style for plates is necessary to be MP Plate - UCS.
Currently PM Plate UCS is not availabl by default.
Ilko Dimitrov
