Hi everyone
it will be nice to add a possibility to create a function in AS to add a block system as autocad do ?
as the user joint system but with no need profil base, just insert point.
as the macro system but will not be just assembly function, and entire set of beam or plate independant of the others object.
It could be great to make only one assembly "block" it and after copy it anywhere it's needed and if there is a modification only do in one and other set automatically.
Now we can use the block command from autocad, but there is some bug as said in my post below (don't show correct quantities and impossibility to create drawing without explode the block).
I made a post on the forum, if you want more information:
https://forums.autodesk.com/t5/advance-steel-forum/possibility-to-create-a-block-of-beams/td-p/71051...
