Advancesteel can not import IFC Tekla
Advancesteel can sometimes not import IFC files from Tekla. If i import the same IFC files into Navisworks or Solibri, these files are imported without any problems. (see attachement)
This is difficult to understand because Navisworks and Advancesteel are both Autodesk products.
Sometimes when i import some IFC files from Tekla, Advancesteel is importing some steel, but then I get a window where I have to convert profiles from Tekla to advancesteel elements. Only there are some problems with the name of these sections (see attachement)
 What kind of section is this:
Tube 60x1.2
Flat 60x12
Hollow section 60x60x1.2
If I choose the wrong section it will be placed wrong into my GTCMapping database for next imports.
1 Kommentar
haedicu
Status geändert in: Under Review
Idee einsenden
