Advanced steel to commom dwg
I would like to convert one advanced steel model to one simple dwg file. For to send for anyone that has just autocad, and they open the file normally, and see just one 3d solid.
1 Kommentar
you could install the Objectenabler, then anyone could see the object.
You could explode your model to just a 3D solid:
-make a copy of your modell, delete all information, you don't need like weldings and so on
-use the Explode command to create Solids, and the "exporttoacis"---result a sat file
- open a new drawing, import the ACIS, and save it as DWG
--> finished
These steps could be find easier by using the Graitec PowerPack, but the result is the same
Idee einsenden
