Advance Steel standard HILTI anchors. Manufactures recommended hole sizes
Advance Steel built in standard HILTI anchors. Manufactures recommended hole sizes/tolerances.
With each release of Advance Steel built in standard HILTI anchors that come with the install.
These anchors should have the manufactures recommended hole sizes (tolerances) for the steelwork loaded into the install database for each type of anchor, rather than having them blank and relying in the default hole size/tolerance. With each release of Advance Steel we have to go through the catalogue and reset the tolerance for each anchor type and size, as they are a part of the standard install.
I would also recommend adding other major anchor manufactures (example: POWERS) to these catalogues for the standard install.
Please add manufactures recommended hole sizes (tolerances) for anchors into the standard install database.
Thank you.
1 Kommentar
ETheuring
You are right. The anchors database in Advance Steel is not actual any more and contains too few manufacturers.
Indeed, there are with this topic a few basic problems:
1. There are no general standards for anchors and every manufacturer makes his own standard.
2. Till present most anchor manufacturers refuse a cooperation with Autodesk and the developers must gather the data laboriously and bring this on the database format of Advance Steel.
Therefore, you should do the following:
Request your anchor manufacturer to a cooperation with the Autodesk Advance Steel development, so that she receives the necessary data in the suitable format from the manufacturer.
Idee einsenden
