Is it possible to create a tool that will work like view base to cut views thru the advance steel model to create views vs. using the sheet set up Advance steel offers. I have used View base with Cadworx and made the views with solid and hidden lines I needed for the project using layers to control what I wanted to see. I like the model views advance steel creates, maybe some how it could be used to import into a sheet view similar to what view base does and still be able to use autocad commands to annotate the sheets. I have used other lisp routines in the past to get 3d cuts from the models. Viewbase gives a good look but could use an upgrade as well. The sheet set up with advance steel need to be user friendly if we continue to use this option. Even needs options of modify the views if need and possible layer control for the construction drawings I need to produce instead of having to try and program a view. I know you can modify the cut line on the view but sometimes the view has to be manually recreated to get the model change.
Is it possible to not keep the sheets in the 3d model file manager?
I don't mind to view set up that advance steel has to offer but for the work flow we produce it causes a slow learning curve. I have set up the views to run for my current company and it seems to run for the most part good, but we still have to add dims, grating hatch, etc to the sheet. One problem I had was when I created the sheets and was working in the model I had a fatal error. so i saved over the old model with the back up file. When I opened my sheets it rev up everything when it wasn't suppose too. I have had problems with dims flipping out of place as well when you do an update. Recently my model shift on the sheet for some reason and had to move it back, seem to have bugs with the sheet set up. Its it possible to improve this part.
