Currently on the Advance Steel Extension for Revit there is no option to set the position to internal or shared coordinates. The issue is some Revit project don’t use internal system and use the survey point and / or shared coordinates etc. When you open Advanced steel and use the advanced import tool and load in the .smlx file. The UCS position is not the same position as the shared coordinates and when exporting the AS NWC’s to Navis the position would be off. Also, another issue is that when you link the AS .dwg in plant3D the position would be the off too. The only solution I found is to create separate AS .dwg and link the AS as an xref and move it to the correct position but this is not ideal when managing models.
