Is there a way to resize the Advance Steel Joint Properties Dialog Box? I work a lot with stairs and the descriptions for Grating and Stair Tread options are so long that the full description does not show up in the small space that shows up. Without being able to make the dialog box larger, I'm guessing at whether or not I have placed the right material in my model until after I have placed it and can check materials manually through the Advance Material Properties.
I know there are scroll bars at the bottom to scroll over and read the full description, but that's rather inconvenient. It would be better, in my opinion, if I could either resize the entire properties dialog box to allow more space on those lines to show the full description, or if that dropdown expanded to show the full description without having to scroll horizontally.
