Adding Fillet weld to Full Penetration weld enhancement
Hi again: :zwinkerndes_Gesicht:
 In Weld Properties, on the weld  main panel it would be  nice to have an additional field below the prefix cell. A replication of the Weld double panel.
Please see 60 second video for clarity.
Juss sayin::denkendes_Gesicht:
Best regards,
Janet
Graitec CANADA
5 Kommentare
Nicht anwendbar
Good idea Janet! :daumen_hoch:
1greg1
Thank you very much Janet.
Hope Autodesk  would take it in consideration adding this option.
Greg Daneshvar
clintstrain
I agree this is an important weld symbol to have.  It is often required on moment connections between beams and columns.
janet_black
That’s why I’m putting it out there. :lächelndes_Gesicht_mit_lächelnden_Augen:
bigcarl5000kg
Hi @janet_black ,
if we were able to enter welds as in AutoCAD Mechanical = graphic interface, your idea would be resolved immediately. Autodesk has this option in stock, just use it ... and the many benefits that result from it (certain user definitions, saving the weld to the library, importing other welds from dwg, ...)
Idee einsenden
