ADD TOGGLE IN MANAGEMENT TOOLS FOR DISPLAY OF ADVANCE DETAIL STYLES
I wish there was a toggle to turn these off sometimes.
At the very least change the order and put user category at the top so we don't need to constantly scroll through the base Advance ones.
4 Kommentare
I started to create a list of blocks which include cameras with a defined style. So I just pic them from the blockpalete and have the style I want, but it could be easier with such a default for all.
markhubrich
Hey @Sebastian_Eiche that's a great idea and one I never thought of.
Most times like when doing stair towers with many same sized model view boxes I will configure one then copy. It seems quicker to rename them  in the project explore and tweak the description note than sifting through the list every time. If it remembered the last choice it would be nice. I'm going to try your method.
Same here, copy and rename is working great. I really like the model view a bit more than cameras. But for example to create detail from a joint--> insert a block (which is automatic explode bei inserting) and having four cameras with the correct style and scale, just type the detail name and change the size of the cameras
Maybe as short example ( in this case the camera boxes fits without adjustment)  https://autode.sk/3e5Fg7P
acbsdesign
@Sebastian_Eiche
For erection details, I made a std group of cameras with a small cross where the center of detail would be, and place at grid intersections. This group stays in dwt file, and it is easier to copy.
Same for AB details, very quck, and parts would carry the joint name of the base plate, so when placed on AB2 with details, the only thing I have to do is move the label down so it becomes DETAIL-1 for example.
The only thing is switching group selection on and off.
My two Eurocents :leicht_lächelndes_Gesicht:
Idee einsenden
