Currently, the spiral stair macro only uses certain railing profiles and only those profiles. This means that the Railing macro cannot be run on a spiral stair, and in order to use the railing you need, the spiral stair would have to be exploded.
Need to be able to add railing profiles to that macro, or configure the spiral stair macro to be able to host a railing in the same way as it hosts a straight or regular railing.
