It would be nice to add objects to an Advance joint without deleting the inteligience of the Advance joint properties box. Example. I have had times when I need to add an additional joist to a Shear plate connection (2 joists connected to the same shear plate). I have achieved this by deleting the properties box, later to find the joists require moving upwards by set distance. Instead of an easy pick & move with the joints following, every single element of the now exploded joints needs to be carefully selected (could be dozens or hundreds) & moved. Things get missed & it becomes a mess.
