Add Grating object to be supported by SMLX import/export file
Currently, importing the SMLX back into Advance Steel, the Grating is imported as a Plate.
The request would be very helpful for Advance Steel – Revit Exchange, since SMLX is the base for transferring the model between the two products.
1 Kommentar
Nicht anwendbar
This is so ovious it should work, that i can not believe it has not been repaired in previous Versions...HEy Autodesk!! Wake up!
Idee einsenden
