Add button somewhere to enable / disable the fitter
Add button somewhere to enable / disable the fitter for concrete objects.
4 Kommentare
bigcarl5000kg
Hi @markhubrich ,
you need a button for this setting in MT?
markhubrich
Yes so I don't need to keep that window open all the time. Quite often I am toggling that fitter during wall & floor modeling.
AleckGiles
In each object's properties, you have a page for Automatic Fitter. this shows ticks for whether to fit each end of the object at all. Also, there is a priority value. The higher priority cuts the lower priority. Using these values you can control the fitting per object without touching the Defaults.  Unticking the Fit at Start and Fit at End boxes is the same as turning off the fitter for that part. And you don; need to remember to do it before creating the part.
Aleck.
markhubrich
Thanks @AleckGiles . That works ok on walls but not so well on slab work.
Mark
Idee einsenden
