ability to quickly add the assembly name to parts in a drawing ,sutch as a ,general arrangement drawing
i think when labeling up a drawing that shows where all assembly parts go (ga drawing) it be good  if wee could quickly an esaly  add only assembly labels
currently (as2019)  if u select labels tool  u get to start putting labels down one at a time or change the lable thats being useed one at a time or do multiple labels at once
but the change label thing has no effect what ever u select u still only get "part single"
and if u use the multi  , then select one label, right click select all , advance properties
it changes the lables to assembly labels  , but it dose not change it to the name of the part u selected
it instead changes it to  the name of every part that uses that single part in an assembly
and L1/12  dose not = L1/1,L1/12
its just not the same  and so u have to edit it
and so u have to know the name of every assembly part u wont to label be for u can start labeling
as a result it so mutch faster to mauly rite lable's on drawing with a pen
am i mising sum thing or has no one at autodesk ever tried to label a ga drawing
Idee einsenden
