2D drawings - green frame around details
green frame.pngThe green (green=basic setting) frame around the details automatically adjusts to the content.
Sometimes additional labels are added to a detail. It is helpful to be able to slide and adjust the frame via "grips"
Der grüne (grün=Grundeinstellung) Rahmen um die Details passt sich automatisch an den Inhalt an.
Manchmal kommen jedoch zusätzliche Beschrifungen zu einem Detail hinzu. Es wäre wünschenswert den Rahmen über "Griffe" schieben und anpassen zu können.
3 Kommentare
Nicht anwendbar
Hi, I discussed that years ago (Oct. 2016 AS Keyuser meeting Bucharest ?) with the dev team. It would be a great help to have that possibility, but I see a big challenge in recalculating the view dynamically. Might be easier to strech the frame and then to confirm to start the calculation as a non dynamic process.
not the best way, but you could add a label to an object like beam or something, change the content to "left" or "right" or something, change the layer to non plot and then move to the place, where the green frame should end. This could be done for each orientation and so I have 4 labels to control the size of the green frame...and yes I really know that this is not a good way :grinsendes_Gesicht_mit_großen_Augen:
markus.poltrock
It's an idea that seems workable. Thanks!
@Anonymous: Please find a flexible solution for the detail frame. With an option to choose automatically adjust or manually (on detail update).
Idee einsenden
