Custom Connection Problem
GHASEM_ARIYANI
Advisor Advisor
GHASEM_ARIYANI
hi
I used the Welded Beams for Custom Connection ans then Save In the ConnectionTemplates Folder and Now Use the others Project, but not create Welded Beam. why?
Is it possible?
If not, why?
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
AleckGiles
In your second screenshot it looks like the welded beam has been created - there is a cyan system line of a compound beam there. So I think something may have gone wrong with the features related to it cutting it away entirely. Try selecting the cyan axis and going to Advance Properties. Then set the Display type to features. Check all the properties and features to see if you can figure out what went wrong there.
Aleck Giles
Application Engineer
Graitec, UK
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
GHASEM_ARIYANI
hi
There is no in the choice of profile to profile settings.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
AleckGiles
HI,
Before you can edit any member placed by the Custom Connection you will need to enable modifications. Double click the blue joint box and then tick "Allow Modifications" then try the compound beam again. If you select the cyan axis and then right click look for Advance Compound Properties and check all of them as well as Advance Properties (depends on the Separated or Complete settings on the Display Type page).
I hope that helps.
Aleck Giles
Graitec, UK
LinkedIn
GHASEM_ARIYANI
hi
in the previous posts, My First cheked "Allow Modifications" .
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
AleckGiles
When you right click on the cyan axis you might have "Advance Compound Properties". If you have, try that. Otherwise I don't know without having all your files.
Aleck Giles
Graitec, UK
LinkedIn
