Zeman export add on ?
donald_livi
donald_livi
Community Visitor
Community Visitor
Hello, I've recently purchased a Peddinghaus Peddiassembler (Zeman Steel Beam Assembler). I'm told there is an  export add on for advanced steel to generate the correct NC and DXF files the machine needs, but i've had no luck in finding it. Does anyone have any experience with this?
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @donald_livi,
Thank you for posting on Advance Steel Forum 🙂
Could you please try this command in a test model (already numbered):
  • ASTM14COMMCREATEZEMANNC
Does it work for you?
Best regards
Emy
Emy Nestor
