Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
weld symbol
2 REPLIES 2
442 Views, 2 Replies
weld symbol
how can I increase weld symbol size or text size, i've changed every setting but no chznge please help me in this
2 REPLIES 2
Go to> Management tools> defaults> use filter> type weld size> expand drawing presentation> click on general> change weld size.  I didn't test this so if it doesn't work i appologize
Emanuel.Nestor
If you are working with Advance Steel (AS) 2016 version, the weld symbol definition (size, text ...) is set in the file WeldTemplate.dwg, located here:
  • [C]:\ProgramData\Autodesk\Advance Steel 2016\Shared\Support\Symbols\
You can modify here the entire configuration of the weld symbol.
Some important notes / remarks:
  • Please make sure that you open the WeldTemplate.dwg file with pure Autocad ONLY. Do not modify it with AS loaded.
  • When modify the text height --> you have to modify the WeldText style. Open the Text style dialog box and modify there the text height
  • The modifications of weld symbol template will be visible only for the new generated drawings. The existing detail drawings will NOT be modified.
You can find more and detailed information in these FAQs:
I hope these will be helpful for you.
Best regards,
Emy
Emy Nestor
