Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Weight on Shipping list - Lot(phase) bom list
2 REPLIES 2
440 Views, 2 Replies
HI
How does Advance steel calculate the "total on phase" line. ?
If you add the part weights i dont get the same weight.
I used the "Shipping list - Lot(phase) bom template.
Jens
2 REPLIES 2
gabriel.costin
It looks that that totals on Lot/Phases are summarized successively from one Phase to another.
Easiest way to find the right weight on a Phase will be to make the difference between two successive Phases.
Not the expected behavior, indeed.
t.bionda
Hi everyone,
I have the same not expected (not wanted) issue with unitary weight on a phase, the token called 'Global weight' is accumulating/succession from one phase to another.
I would like to have after each phase total weight of certain phase, which token I should use? or how to do it in general?
Thank you
