Vertical bracing worklines at beam centerline when beam alignment is "top"
09:59 AM
I am using top of steel alignment for my beams. However, I would like to use the centerline of my beams as the intersecting work point for my vertical bracing. Is there any way to do this without having to use center alignment for my beams (which would be a pain in terms of lining up all steel floor beams at a floor level elevation-wise)?
I think you can use the "offset" feature in the bracing dialog box, but I think with this option you are stuck with the same offset distance at each end of a braced bay, which brings up another question. What if you require different offset distances at each end of a braced bay?
