user template_field_content_ can't save in user BOM template_parts_list
frankLT5JV
frankLT5JV
Hello ,
if i want to save my company name with field content changing in User template/ Plate list for example it doesn't change when i re use the template after "saving template"  .  If i try in other user BOM templates same problem . Always getting back the original template with logo "my company " in the template.
How to solute ?
thanks for the input
Sebastian_Eiche
That's because if an error message tag in the Field.
If you have a look on the right side after selecting the field, you will see the property 'tag'. You could delete this and then change it as you want.
Another way would be remember the number which is used in the tag field and then open the management tools.
Now you open the table editor, and then in the upper left 'all installed databases'. Now use the filter and insert 'error'. You should find the table 'errormessages', select it and have a look for error key which you remember.
In this line you should find the cell content: company. This could be replaced with your company name and if you now have a look in the BOM editor, all templates should have your company name.
I'm writing this with my mobile phone, so if you don't find it maybe someone other could take a pic for you or I will do it tomorrow.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
frankLT5JV
Dear ,
It is fixed !
Thank you soo much for your input .
I realy appriciate !
If i've got troubles on the way i will try to contact you
Many thanks
KR
Frank
