Upgraded Prototype to 2023
Julio_Soto
Advisor Advisor
Message 1 of 9
Julio_Soto
I'm using AS 2023 and when I create a drawing I get this message
It says my prototype is from a former release AS 2021. I've opened this prototype in AS 23 and saved but I still get this message. Anyone know how to fix this?
Replies (8)
Message 2 of 9
robertwmerriman2
Hi @Julio_Soto
Do you have any BOMs on that prototype if so you will need to open and save those as they will still be 2021 versions
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Message 3 of 9
Julio_Soto
I do not have boms in the prototype
Message 4 of 9
robertwmerriman2
@Julio_Soto
Could you upload your prototype so we can have a look
Message 5 of 9
Julio_Soto
Sure, thanks for taking a looK!
Message 6 of 9
crydee-AG1
The prototype is definitely in AS2023 format and is fine for me. Perhaps you have linked files like a UPD  or MDF file with the prototype in the folder on disk. Make sure the DWG is the only file with this name in that folder and test again.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Message 7 of 9
Jonathan.Jasinski
I have had this problem when the user doesn't have permissions to the Data Folder that contains the prototype.  Even opening and "saving" says everything is fine, but it doesn't actually save/update anything because you don't have permission to change stuff in the Data Folder.
Message 8 of 9
Julio_Soto
So it looks like I had to upgrade all the symbols that get imported into the drawing as well. It's a bit irritating that AutoDesk doesn't just upgrade these themselves when they put out a release lol.  Anyways, this was the fix for me.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Drawing-conversion...
Message 9 of 9
sales7NF7D
Interesting.
I have heard that we should all do a Project Convert on all the country folders that we use to ensure the latest .dwg are used and the everything is using the most current version of the SQL databases.
