Unstacked Dimensions Too Small
mcichecki
mcichecki
I updated my dimension style to un-stack dimensions, but even as they are unstacked they are very small. I tried removing the inches symbol, thinking it was adjusting the text size down, however when i use parametric dimensions the inches symbol is still present. Screenshots attached.
How do i get my fractional dimensions to be the same height as the rest of my dimensions?
Thanks in advance!
acbsdesign
@mcichecki
Hi, Below is a test with unstacked dimensions, I did set to 0.95 size, Architectural, and they behave as they are supposed to:
HTH.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
mcichecki
Thank you!
