UNDO ... CTRL-Z .. NO WORK PROPERLY
muleman1
Advisor Advisor
muleman1
 @Emanuel.Nestor or @AleckGiles is there a fix or workaround for the snafu with UNDO / CTRL-Z ? or is it just our machine?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
AleckGiles
Undo is behaving strangely in AS2018. Autodesk are aware and the developers are investigating.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
JPNR87
Hope that ctr+z failure fix gomes soon. Very disturbing to fear false move and no ctr+z poissibility to go back. :S
markhubrich
Are you referring to the million and one undo steps to undo one command?
...and fix the kiss export issues.
JPNR87
yes, I need to hold down ctr+z for many seconds and hope that it works or I have saved moment befor that file.
DumitruBerteanu
Hi. I can confirm that this issue is under the development team investigation and we hope to release a fix for it soon.
This undo strange behavior appears because in the Undo list you get some repetitive items, that get added each time AutoCAD tries to read the Advance Steel object properties. So, if you are in shade and move the mouse over multiple elements, those incorrect items get added to the list, making undo very difficult. A workaround would be to turn off the "Roll over tooltips", while working in the model.
Dumitru Berteanu
Product Owner
