Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
The angle property is irreversible - is there any way to change this behaviour?
3 REPLIES 3
brisid.isufi
303 Views, 3 Replies
When I change the angle of a straight steel beam, the beam is rotated accordingly. For the sake of simplicity, say I specified an angle of 15 degrees. When I reopen the edit window, the angle field returns to zero, but the profile remains rotated. Is seems that the angle is not a property after all, but it is an irreversible command that applies a transformation to the beam. If I want the beam to go back to the initial state, I have to specify an angle of -15 degrees for this example. Is this a bug or is this considered a feature of Advance Steel? Please see the figure below.
Labels (4)
3 REPLIES 3
Hi @brisid.isufi ,
it's standard behavior - Advance Steel doesn't remember this setting here ... you can note the rotation value for yourself, e.g. in user attributes, for later cases
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
brisid.isufi
in reply to: brisid.isufi
Thanks. I hope this is improved in the future.
Create a new request in Advance Steel Idea Station, so users can vote on the need and give Autodesk feedback.
