Suppressing Ext. Line in Parametric Dimensions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello to all,
I hope this message finds everyone well.
I am running into an issue with suppressing the extension line of parametric dimensions.
After creating a new dimension style and going into the modifications, I am suppressing a line to have one be invisible and the other to appear. Please see below image for reference:
After going into my drawing (in this case, a GA Plan drawing), I try to place parametric dimensions and notice that both extension lines are suppressed.
When I use the regular dimensions, only one dimension line is suppressed and this is working correctly. It seems to only be an issue for parametric dimensions. I have also attached two images below for reference:
You can see in the left image, these are parametric dimensions. The defined points are shown at grid line intersections on the top left and bottom right, as well as the column. Both extension lines are not being shown.
However, in the right image, these are the regular dimensions. The correct extension line is not being shown.
Could anyone please provide some insight on this? Maybe this does not work for parametric dimensions at all but not too sure.
Thank you all for your time.
