Steel to wood connections
Jeetender_kaler
Jeetender_kaler
How do i join wood to steel? Almost every joint i use breaks or doesnt work.
muleman1
It may be possible to create a new user "beam", giving it the dimensions and properties of the wood member you are using, then in theroy the joints should work. There are many threads and google search results on adding a beam to your database
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Tomislav.Golubovic
What kind of joint exactly?
