Stair Anchor Base Plate - Reference Point
C_Reiter
C_Reiter
When using the connection "Stair Anchor Base Plate" in the Connection Vault. What is the reference point for that you asked about at the beginning of the command. I was thinking that point is what is used as the reference point for the cut/nose plate part the command. That would make more sense then the default location(top of stringer at bottom elevation). I have always used the noise of my bottom tread to locate the vertical on my stringer.
I am using AdvanceSteel 2023 64-bit Build 601, Aug 12 2022.
Rob_Merriman
Hi @C_Reiter
You are correct, if you dont select a reference point then all of the setting out values will run from the end of the stringer system line.
If you choose a reference point then the horizontal / vertical dimensions will use this point.
In my example below the reference point is the nose of the first tread
Rob Merriman, AEC Technical Lead, Graitec
C_Reiter
Thanks Rob! I overlooked changing the "Cut layout and size" from "horizontal" to "reference point". I was thinking it would automatically use the reference point.
alickomay
can this be use to change hight of stringer base plate
