SP Plate drawing question
St.Jordon
Message 1 of 26
St.Jordon
I  reinstall  AS 2023, and i want to get the sp plate drawing from the model,bu it not works well,  not always show the object top, what's wrong with this?    1.png2.png
Jordon
Replies (25)
Message 2 of 26
Flies-Eyes
Check your CS orientation for those objects which are showing the side not the top.
Message 3 of 26
St.Jordon
can you pls show me some pictures? I'm not really under stand, thank you.
Jordon
Message 4 of 26
St.Jordon
can you tell me how to deal with this problem step by step?
Jordon
Message 5 of 26
Flies-Eyes
Message 6 of 26
St.Jordon
I clicked this ,but the drawings still as the same before, what' wrong?
Jordon
Message 7 of 26
St.Jordon
Here's the model
Jordon
Message 8 of 26
Flies-Eyes
Firstly check the plates to identify their CS.
If the CS orientation is incorrect then change the UCS to the correct plane, and use the button on the pallette to Redefine the CS orientation of the plate.
Message 9 of 26
St.Jordon
how to  Redefine the CS orientation of the plate about this situation ?
Jordon
Message 10 of 26
St.Jordon
email address: 88517721@qq.com
Jordon
Message 11 of 26
Flies-Eyes
The easiest way to get rid of any CS orientations that have been set accidentally is to remove numbering and renumber. This will get rid of any CS settings, which is normally a pain for me but in this case it will reset them all.
I have attached plate drawings run through my system.  They seem to be working fine.
If you delete your numbering, and re-number I would think your drawings will update to the correct orientation.
Message 12 of 26
St.Jordon
I renamed all the parts, unfortunately, still the same , I don't know how to do now, strange...
Jordon
Message 13 of 26
Flies-Eyes
Did you delete the old part numbers?
Message 14 of 26
St.Jordon
yes, even i create a new drawing ,and copy one part to the  new drawing, result still the same1.png2.png
Jordon
Message 15 of 26
Flies-Eyes
Just to confirm, you are using these buttons to delete numbering?
Message 16 of 26
St.Jordon
yes just these buttons
Jordon
Message 17 of 26
Flies-Eyes
This is what my part CS orientations look like after I delete numbering and renumber.  You can see they are different to yours.
Message 18 of 26
St.Jordon
NO  ,  my  drawing not like this, all top
Jordon
Message 19 of 26
Flies-Eyes
Ok, this would indicate the numbering hasn't been deleted.  Maybe use the toggle button and delete prelim, part and assembly numbers and then run numbering again.
Message 20 of 26
iwafb
Please change the drawing style settings from "model Z top" to "Horizontal - Object Z Top". This should force the "top" to come from the part and not the model. You will need to re-create the drawings...
