Hello all,
I want the joint box for the slave joints to appear automatically just after giving the connection. Whenever I give a connection using "create joint in the joint group" the joint box doesn't appear for the slave joints and to see that I have to open the advance joint properties of that connection. This process adds extra work and if I don't turn it on, while modification of the structure there are possibilities of mistakes. However, when I use "create joint in a joint group, multiple" the joint box automatically appears for the slave joints. In defaults, the setting for the joint box is set to show a joint box right after creation. Still, it is not working.
