Single part label formatting (Stacked diagonal fractions for imperial angles, small "x" between numbers)
Using AS 2022. I'm currently working on modifying the part labels to suit our needs, and I'm struggling with a couple things:
-Stacked diagonal fractions for imperial section names (Eg. L3 1/2x3 1/2x3/8. I would like to stack all of these fractions diagonally)
-Changing the "X" between Section Size and Weight to be lower case instead (C10x15.3 instead of C10X15.3)
-If the fraction can be stacked diagonally, I'd also like to remove the space between the whole number and the fraction to shrink the label size a bit.
See pictures below. Red is current state. Green is desired state.
Even if I have to go through one of the tables and manually change every section name to make it happen, that's alright. I'd rather spend the time doing something once that will keep us from having to use a workaround or manually change something every time. Point me to the right items to change and I'll make it happen.
If anyone has some insight on any of these challenges I'm facing, please let me know. Thanks!
