When a shop drawing is produced it has a scale that is controlled by the style manager. I want to know how I can find out that scale without going through the "detail drawing properties" and reading it of the dialogue box. In other words I would like to know if there is a command that will show the scale on the command line.
Regards
Tony
You can add the SCALE token into the title block and this will automatically show the scale of the detail. I don't believe there is a way to show it on the command line, but this works if you don't mind the scale showing on the drawing.
