shear stud dusplay problems
Message 1 of 10
Cannot get nelson studs to fully display with the head on the stud either in the model or in the drawings. Please help.
Replies (9)
Message 2 of 10
Adrian.Mangan
Hi, in my experience if the length you require is not listed in the database it will appear with no head. You will need to go to management tool, shear studs then go to type you use and add the length you need in the last tab. Tomorrow I will add some screenshots for you, hope this helps
Message 3 of 10
steeldesgn
You have to use the length that Nelson stud has, so if you want a 6" stud you might have to enter stud length as 6 1/4. The length in the data bases are the lengths before welding.
Message 4 of 10
I used the nelson H4L type which isn't the default but I used the size in the database,  nothing different.
Message 5 of 10
I used the nelson H4L 1/2" diam x 5 1/ 8 right out of the box . Still have the problem.
Message 6 of 10
Adrian.Mangan
Maybe this will help, did up a little video to illustrate
Message 7 of 10
Thanks. I'll give it a try.
Message 8 of 10
ecapati
do you have an easier way to put those studs on an angle?
the way Im doing it is I rotate the USC every single time I need to put a stud on an embed angle.
I'm Just curious if there is an easier way. Thank you in advance
Message 9 of 10
I think you have to use the UCD
Message 10 of 10
RonBuckingham
I had this same problem. You need to put in the lengths exactly. Here is a list I found on Nelson Stud Welding website. Try putting in 5 5/16" instead of 5 1/8" for the 1/2" H4L.  Its weird, 5 1/4 wont work, 5 5/16 will, 5 3/8 won't.  I printed this out and put it in my Advance Steel notes. Ron
H4L 1/2 X 3 1/8 MS
H4L 1/2 X 4 1/8 MS
H4L 1/2 X 5 5/16 MS
H4L 1/2 X 6 1/8 MS
H4L 1/2 X 8 1/8 MS
H4L 5/8 X 2 11/16 MS
H4L 5/8 X 4 3/16 MS
H4L 5/8 X 6 9/16 MS
H4L 5/8 X 8 3/16 MS
H4L 1/4 X 2 11/16 MS
H4L 3/8 X 3 1/8 MS
H4L 3/8 X 4 1/8 MS
H4L 3/8 X 6 1/8 MS
H4L 1/2 X 2 1/8 MS
H4L 1/2 X 2 5/8 MS
H4L 3/8 X 1 5/8 MS
H4L 3/8 X 1 3/8 MS
H4L 1/2 X 3 5/8 MS
S3L 3/4 X 3 3/16 MS
S3L 3/4 X 4 3/16 MS
S3L 3/4 X 5 3/16 MS
S3L 3/4 X 6 3/16 MS
S3L 3/4 X 7 3/16 MS
S3L 3/4 X 8 3/16 MS
S3L 7/8 X 3 11/16 MS
S3L 7/8 X 4 3/16 MS
S3L 7/8 X 5 3/16 MS
S3L 7/8 X 6 3/16 MS
S3L 7/8 X 7 3/16 MS
S3L 7/8 X 8 3/16 MS
S3L 3/4 X 10 3/16 MS A
S3L 3/4 X 2 3/16 MS
S3L 3/4 X 4 3/8 MS
S3L 3/4 X 3 7/8 MS
S3L 3/4 X 4 7/8 MS
S3L 3/4 X 3 3/8 MS
S3L 3/4 X 5 7/8 MS
S3L 3/4 X 5 3/8 MS
S3L 1 X 6 1/4 MS
