Screen Issues
Screen Issues
Seamant1967
Screen Issues
Seamant1967
Is anyone else having issues where your tool bars are locating themselves just off the screen far enough so you can't move them or access all the tools? I was gone on vacation for a week and this is what I came back to.
Jonathan3891
Have you tried selecting your workspace again to see if that fixes your toolbars?
Jonathan Norton
Blog | Linkedin
pendean
Community Legend
Community Legend
... and are you manually saving your workspace with WSSAVE command after you move them back?
Ensure your AutoCAD/AS program screen is fully expanded as well.
Sebastian_Eiche
do you maybe mean the AS toolbars? This problem sometimes appear if the xml fiel was not wrote correct. In my case: sometimes by having to much version open or a crash.
It's easy to repair:
  • Close AS
  • delete the ASSettings.xml int he path of Advance Steel:
C:\ProgramData\Autodesk\Advance Steel *installed version*\*installed location*
For example AS2021 international: C:\ProgramData\Autodesk\Advance Steel 2021\INT
You could also open the ASSettings.xml and have a look for the palette and often you will see a negative high value like -32000 --> just change it to "0" and it will also be in place
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
