Rolled plate: Generate Detail Drawing with expanded/ unwinding flat development plate
votuananhvungtau
votuananhvungtau
I have some rolled plates (flat bar, rolling with a radius).
Anybody please hepl me to generate Detail Drawing completed with expanded/ unwinding flat development plate.
Thank you !
AleckGiles
You have modeled those objects as cruved beams. That means you will get Curved beam drawings. While it is possible to get a drawing of a staightened curved beam that woud require a fair bit of effort cretign a new drwing style.
If you want flat patterns you should model the objects as Folded Beam or Folded PLate not curved beam. Folced PLAte will be faceted flat sections so you might be best off using Folded Beam. Draw the curve and a line perpendicular to that for the system line. Then create the Folded Beam from the curve usign hte ends of your cosntruction line as the system line.
The resulting Folded Beam will automaitcally produce a flat pattern drawing and will have only one fold line on it. You will need to dimension the radius manually.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Julio_Soto
So what would be the other method that would take a while?
sirving
Community Visitor
Community Visitor
The only issue I have with this methods is if you use a folded plate depending on the amount of faces your stretch out changes. If I an to roll a piece in a roll what method should I use so flat blanks are correct size?
AleckGiles
Hi @Julio_Soto
The other method is to set up a drawing style where the main part beam presentation is set to "Visible unwinded" and that draws the curved beam straight.
LinkedIn
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
