Rod with threaded end connection
HarryHighpants
Message 1 of 16
HarryHighpants
Anyone know how to join two beams with a round bar that is threaded at each end?
All the wind brace macros seem to use those round brackets, which i dont want.
Replies (15)
Message 2 of 16
EddieSaez
Can you provide an image of what your afer?
Message 3 of 16
HarryHighpants
Hi Eddie. This is what I mean:
Message 4 of 16
I don't think this is possible as a connection. This is something that I have asked for on the Ideas forum that has been marked for Future Consideration. The option to create a threaded rod or put a thread on the end of a rod would be very useful, as well as the option to add a nut and/or a  nut and washer washer at a location.
The way I do this is create a nut in AutoCad as a special part, ensure you have a top and bottom point added for insertion. Insert into Advance as a Special Part. Create the rod as a round bar and give it a descriptive nmae in the Naming tab of the rods properties. Drill the holes in the members, place the nuts and you have what you require.
I have had many projects where a nut needed to be welded to a beam underneath as well as threaded rod assemblies. It is something that other detailing packages do so there is a need for this to be added to Advance steel as well.
I hope there is an easier way to do this, if not give it a push on the ideas forum.
Message 5 of 16
EddieSaez
I had an idea on possibly using Rod bracing, but I'll need to investigate this further.
Will let you know of my findings.
Message 6 of 16
Jonathan.Jasinski
So, I was actually able to add Threaded Rod as a bolted connection through Management Tools. The trick is to uncheck the box that says "Finish at gap" or something like that. I'm not saying that making the threaded rod table was easy, but I did do it and it has been very helpful.
Message 7 of 16
That's good, but wouldn't it be better if it was part of the bolt / hole / anchor tool as an option, say tie rod where you had a setting indicate fully threaded, thread one end or both ends and thread length. Also add an option for NaW, 2naW plus also add a nut to both sides of the gap if required.
OK, programmers the hard work has been done for you, make it so. Smiley Wink
Message 8 of 16
HarryHighpants
Thanks guys.
The way I achieved it was to create a round rod beam and then use a parametric cut-out with clearance.
Not perfect, but it sort-of works. The main draw-back is that AS treats the hole as a cut-out, not a hole, which of course means that you cannot label the hole in your drawing.
Message 9 of 16
EddieSaez
That was going to be my next avenue, invesigate the possibility via the bolts database
Message 10 of 16
Hi All,
Similar to all of this, can someone help me with this:
How to make this kind of connection between two plates with threaded rod, bolts, nuts....
Thanks.
Message 11 of 16
lk
I have created user sections type: M16 DIN975, M20 DIN975 etc., just as a round bars made of steel 8.8 or any other added to the base.
Nuts and washers are special parts:
Leszek K
Message 12 of 16
muleman1
@HarryHighpants dunno if this is OK, it may be dumb. But we found it better than nothing.
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Message 13 of 16
Sebastian_Eiche
There's no automatic for this. The most use a round beam and add customer connections for the nuts and washer. You could use a self defined weld type for adding an automatic label for the threaded length.
Another way could be to use the AG rod connection from the connection vault and change the specialparts in the databases to nut and washer soli ds . I knew a few are using special defined bolts or anchors, but the set s in the databases are limited to 6 pieces so you had to use specialparts for the nuts and washer to get the whole sets in some cases.
By using special parts, there is the problem with the bom list (special parts in the boot list). In the original installation you only had all or no special parts. But there's very nice knowledge for the xslt customizing...special parts with a specific role will be part of the bolt list.
Regards
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 14 of 16
Thanks for quick reply. I`ll try to do all of the above and see what`s best in this case.
Thank You all.
Message 15 of 16
I'm sure everybody has alraedy considered this but, what about using a sag rod connection? Is that possible?
Message 16 of 16
AleckGiles
Further to other replies check out John Bennett's blog here Studding blog  for another suggestion. Obviously not infinitely variable (defined length rules only) but pretty close.You only have a fixed stud length on the "head" end too but you get full details in the BOMs and the nuts and washers are placed for you without needing special parts.
Not perfect but this works pretty well for most things.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
