Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Registering Custom Plugin Advance Steel 2019
wagnermichaeljames
wagnermichaeljames
What is the correct method for registering a 3rd-party plugin (.dll written in C#) wwith Advance Steel 2019?
The API documentation prescribes 3 different plugin registration methods for Advance Steel 2017+, however none of them have so-far worked. All of them involve making a ASSettings_Advance.xml file and then putting it different folders.
I've tried:
1) editing the registry key with the path to the ASSettings_Advance.xml file
2) Simply creating an Addons folder, in main AS installation folder, which contains the xml file.
3) Placing ASSettings_Advance.xml in the C:\Program Files\Autodesk\Advance Steel 20XX\Common\Bin\ folder, trying both 2017 and 2019.
Any tips would be greatly appreciated.
ChristianBlei
I use 2, works perfectly. My path is
C:\Program Files\Autodesk\AutoCAD 2019\ADVS\Addons\CBT_AS_IdeaStatica.xml eg.
with
<?xml version="1.0" encoding="utf-8"?>
<AddonsData xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Addons>
<Addon>
<Name>CBT_AAS_IdeaStatica</Name>
<FullPath><Value Name="InstallLocation" Type="String">C:\Program Files\Autodesk\AutoCAD 2018\ADVS\CBT_AS_IdeaStatica.dll</Value></FullPath>
</Addon>
</Addons>
</AddonsData>
HTH,
Christian
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
