Regarding Filtering Labels...
Lewk_PSB
Lewk_PSB
Now would be as good of a time as any to have this implemented...
This happens way too often. I put together a project, and then I create the elevations/plans. I don't have details of the parts yet because the field erection drawings [read: GA drawings] need to be approved. However, our fab shop wants to get a list of material together for ordering, which means I have to run numbering and give them a Material Summary List. Then when I update the erection drawings, it turns into one of those Magic Eye puzzles with the brilliant display of new labels thrown everywhere.
Yeah, I could turn off the automatic labeling, but if I do that now I'll have to completely redetail the entire drawing with a new Dimension Style. Having so many DStyles gets tiring and confusing, and if you realize you're using the incorrect one you'll just have to grin & bear it.
This one is a bit of an extreme example because we're using bent plate clips for connecting light gage framing, so there are hundreds of these plates (sidenote: it's also a BLAST running at 2FPS with the 3,000 screws I've had to insert as special parts). I've already spent the time to tailor the labels manually, so selecting only the labels via Select Similar is out of the question.
Carpal tunnel, here I come! Unless someone knows a way out of this?
johnjmbennett
the only way is to create a dedicated drawing style, that controls the model object type labelling content, based upon the model role of the clips you create,   then add this model object to the drawing style presentation and set the labelling to off.
you can create a custom model model  like   Cold rolled clip,  then turn this into an model object in the Drawing style system,  then add this to the drawing style and set the label content to  Off.
you maybe able to shoehorn this into an existing user style, as a custom line and update the drawing, depends what style branch was used to create the drawing from in the first place.
John Bennett
