Railing Max Fabricated Length
markhubrich
Advisor Advisor
markhubrich
Is there a setting somewhere to set the maximum length a single railing can be before dividing it up?
As an example, lets say I have a straight run that's 100feet long. I am obviously not going to fab a 100 foot railing. I could split the members I'm attaching to I suppose and AS will create separate rails. I would rather set a constraint similar to the post spacing function.
Thanks!!
Mark
...and fix the kiss export issues.
To my knowledge, there isn't, and it sucks.
I go through the trouble of setting up my field splice locations prior to running the rail macro, so I know where to start & stop.  It's a pain to put it mildly.
mick-CNF
Something I have done before is to do a short run of balustrade the length I want to fabricate then copy the whole thing including the joint box to complete the long run, then if I need to change anything I modify one short run and then transfer properties to the others.
If this information solves your problem please accept as a solution.
acbsdesign
@markhubrich
There is an idea in the idea station for voting.
https://forums.autodesk.com/t5/advance-steel-ideas/railing-macro-improvements-added-items-and-summar...
Regards, Ilko Dimitrov, ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
