Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Railing>PostConnection different options?
2 REPLIES 2
paul.toth
291 Views, 2 Replies
I have a question, why in a drawing model, the railing object, in Post Connection sometimes has 4 options and sometimes has 9 options, example the images:
Notes:
- I didn't modeled the drawing, I need to change the existing 4 options in the 9 options version
- at this moment, I was not able to find any differences in the final view (profile sections, dimensions), excepting the connection
- in the ManagementTools > AstorRules > I saw that there are several versions of Railing_Postbeam0 to 6, I don't know when is reading witch rule
-I am working in Advance Steel 2019.
thank you, with respect, Paul
Labels (2)
2 REPLIES 2
johnjmbennett
in reply to: paul.toth
The post alignment is set to top of a beam, you do not get the additional side face fixed options.
look under the post tab,  should see  alignment  for top/left/right.  Change to left or right you have more fixing types.
cheers
John Bennett
paul.toth
in reply to: johnjmbennett
Thank you, is working 🙂
