Publishing Tool
Publishing Tool
Flies-Eyes
Advisor Advisor
Publishing Tool
Flies-Eyes
AdD 2023 I had been using the Publishing tool in lieu of the batch ploting.
In AdS 2023 the Publishing tool is no longer working.  It only plots the prototypes.
Any ideas why this had stopped working.
Dias_Antonio
@Flies-Eyes
Can you post a picture?
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Flies-Eyes
I have managed to solve the issue.  It was, as I expected an object enabler issue.  It appears that as part of the new new productivity strategy from Autodesk, Users need to Uninstall and reinstall this year's and last year's applications as practice and for fun.
So in summary if you find your Autocad Publishing tool is not working in Advance Steel it could be the conflict with object enablers.
johnjmbennett
hi,
so this post here on AS forum seems to have solved the issue with the publish command:
https://forums.autodesk.com/t5/advance-steel-forum/advance-steel-object-enabler-problems-with-autoca...
John Bennett
Flies-Eyes
@bagyt_b to resolve the Object Enabler issue we had to uninstall AdS 2022 and AdS 2023 and reinstall to get it to work.
