process scripting
process scripting
Sebastian_Eiche
Mentor Mentor
Message 1 of 10
process scripting
Sebastian_Eiche
I trying out the vbscripts in the process manager. I'm using it to search for foldedbeams and so on without using a modelrole. Does anyone try to search for a special profile? I want a script only for u-profiles, does someone have some experience with such a script?
And another question:
In the labeling dialog, there's the opportunity to use a VBscript, does anyone know how to use it?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Replies (9)
Message 2 of 10
I use it for secondary parts drawings.
DSTVType for U-Profils is kU
'Returns true for U profiles
Function checkElement(Obj)
    checkElement = False
    'Verify only for beams
    If Obj.IsKindOf(kBeamClass) = True Then
        If Obj.getProfType.getDSTVValues.DSTVType = kU Then
		checkElement = True
End Function
Hope it can help...
Regards
Message 3 of 10
Sebastian_Eiche
where do you found this strings? I have look in the documentation and found nothing belonging to this.
Sebastian Eiche
Message 4 of 10
Don't remember... Inspired by an exemple and partially wrote by myself,
Message 5 of 10
Buxtehude1963
I would use scripts, and I had the same problem in the previous post.
But I do not have U profile, but others: where can I find other DSTVType codes?
Message 6 of 10
Sebastian_Eiche
I didn't see the post...maybe to late, but could be helpful:
have a look in the Management Tool--Table_editor--AstorDetails--Beamtype.
I think this is what you're looking for.
Sebastian Eiche
Message 7 of 10
ChristianBlei
The values Alerat doesnot recall where he found them are the constants in the table eDSTVType of both
 Interop.AstSTEELAUTOMATIONLib5 and Interop.DSCPROFILESACCESSCOMLib libraries of the COM API. The enums are
eDSTVType
kI=0
kL=1
kU=2
kB= 3
kRU=4
kRO=5
kM=6
kC=7
kT=8
kZ=9
kKA=10
kKF=11
kKQ=12
kCCS=13
kPL1=14
kPL2=15
kSO=16
kCSE=17
In the script Alerat used he checked if the DSTV type of of profile is kU which is a U shape.
The script is written in VB.
Christian
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
Message 8 of 10
alickomay
i just used this thread to help make a script to use a a certing drawing style for I section
just had to copy alerat  scrip an change ku to ki
but it was not working and i spent a lot of time  trying to figure out y
turns out u need to restart AS after making a change to a script in the style map
Message 9 of 10
ChristianBlei
from what I recall a restart is not necessary, but you have to close the drawing style after the editing and saving of the sript and update defaults in settings.
HTH,
Christian Blei
Christian Blei
christianblei.de
Message 10 of 10
Sebastian_Eiche
By using the scripts in the process manager I have the same to do.
Restart AS is sometimes necessary in my opinion
Sebastian Eiche
