Problem Sync between advance steel and revit
Hi
I am Having problem sync between Revit and Advance steel.
the complete model is not getting imported in revit . also connection are not showing .
yurikim
Thank you for your posting @Anonymous.
Synchronization dialog says connections are already in Revit model. You might want to check the level of detail in the view in Revit. Connections will be displayed in "Fine" detail. If you still don't see connections, check the Visibility/Graphics overrides (shortcut: VG or VV). Navigate Structural Connections > Expend the items and check the items you want to display.
Hope this helps. If you still don't see it, please upload your sample Advance Steel model here.
Yuri Kim
Product Support Specialist, AEC
Thanks Yurikim for the input, but i already check the VG settings . it does not work .
I am able to put connection in revit but not import from advance steel .
my be something wrong with my workflow or modeling or some library missing .
I am attaching both the files for your reference .
múinteoir
Connections on tapered beams do not come into Revit currently. These beams are imported as plates in Revit and a connection cannot be added to a plate.
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Thanks Jonathan for your insight .
can you recommend any workflow for the purpose of coordination and publication of the model ?
Thanks .
