Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I am having troubles getting the grid lines I model on a plan (lets say XY plan) to show on the elevation views drawings I generate with cameras.
These grid lines are showing on a camera parallel to the plan with the bubbles and everything but they do not show on elevation cameras (perpendicular to XY plan mentioned above). Only a flat line object shows (that is indeed an AS grid object).
I added pictures and a dummy model to show my issue.
This used to work on previous project (see screenshots) but I might have a change a parameter somewhere and it is not working anymore.
Here are some additional detail for my settings:
- I am using AS2023.1 (international)
- Management tool setting "Display horizontal grid line in details" is ON
- The camera box are big enough to include all objects
- I modeled vertical beam at some grid lines node
- This used to show on previous project elevation cameras but I export the cameras again it is not showing anymore...
- I cannot upload the previous projects but I am uploading a dummy project that has the same issue.
Any help would be much appreciated.
Thank you.
I think you need to perform a test with a new camera depth or in other cases there is a bad relationship with the layer assigned to this grid lines.
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
