[.net api] contour information
sapch
Message 1 of 10
sapch
I want to get the 微信图片_20200910155029.png of a curved beam after cutting through a plane, such as points or curves. I tried to implement it through "imodeler" and "extensions", but there was no result in the end. Please help me!
@ChristianBlei
Replies (9)
Message 2 of 10
sapch
I want to get the contour information of a curved beam after cutting through a plane, such as points or curves. I tried to implement it through "imodeler" and "extensions", but there was no result in the end. Please help me!
Message 3 of 10
ChristianBlei
  • you can try to get the modellerbody of the beam (there are variations of the modellerbody for different purposes)         public Autodesk.AdvanceSteel.Modeler.ModelerBody GetModeler(Autodesk.AdvanceSteel.Modeler.BodyContext.eBodyContext bodyCtx)
    Member von "Autodesk.AdvanceSteel.ConstructionTypes.AtomicElement"
  • Then you can get the brepinfo of the modellerbody      ModelerBody.getBrepInfo(Autodesk.AdvanceSteel.Geometry.Point3d[], Autodesk.AdvanceSteel.Modeler.ModelerBody.FaceInfo[])
  • The iterate trough the faceInfos to get the sequences of the vertices for the faces.
I guess you will mget polygonal planar faces.
Or
You could check what you get if you use the IntPtr of the underlying body. My hope ids that this would return the AutoCAd Solid3D that you get when you explode the beam. Of the solid you could access the solids BREP ( you would have to reference   acdbmgdbrep.dll).
Good luck!
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
Message 4 of 10
sapch
Thank you very much. @ChristianBlei
Message 5 of 10
sapch
@ChristianBlei  The function has been implemented. Thank you very much
Message 6 of 10
iwafb
Hi @sapch ,
Would you be willing to share your process to achieve this?
Message 7 of 10
sapch
public void BeantBeamCutPlate()
UserInteraction.PrintMess("请选取梁:");
ObjectId asObjectId = UserInteraction.SelectObject();
UserInteraction.PrintMess("请选取板:");
ObjectId asObjectIdPlate = UserInteraction.SelectObject();
Polyline3d polyline = new Polyline3d();
List<Point3d> arraylist = new List<Point3d>();
List<Point3d> resP = new List<Point3d>();
using (DocumentAccess documentAccess = new DocumentAccess())
if (asObjectId != null)
Plate plate = DatabaseManager.Open(asObjectIdPlate) as Plate;
Matrix3d matrix = new Matrix3d(plate.CS);
matrix.GetCoordSystem(out Point3d ptOrt, out Vector3d vx, out Vector3d vy, out Vector3d vz);
FilerObject filerObject = DatabaseManager.Open(asObjectId);
if (filerObject != null && filerObject.IsKindOf(FilerObject.eObjectType.kBeam))
Beam beam = filerObject as Beam;
ModelerBody modelerBody1 = beam.GetModeler(BodyContext.eBodyContext.kNormal);
modelerBody1.IntersectWith(plate.DefinitionPlane, out LineSeg3d[] lineSeg3s);
int n = 0;
foreach (var item in lineSeg3s)
if (n < lineSeg3s.Length / 2)
arraylist.Add(item.MidPoint);
n++;
getPath(arraylist, resP, arraylist[0]);
for (int i = 0; i < resP.Count; i++)
polyline.Append(resP[i]);
PlateContourNotch plateContour = new PlateContourNotch(plate, 1, polyline, vz, vx);
plate.AddFeature(plateContour);
documentAccess.Commit();
Message 8 of 10
iwafb
Thanks heaps, I wasn't sure how to actually generate the shape...
Message 9 of 10
sapch
Message 10 of 10
calogero_pullara07
Hi @sapch ,
Would you be willing to share your function
too, please?
