Need help learning advance steel 2025
russel
russel
im brand new to advance steel 2025 and im looking to learn the basics to get started, are there any videos or articles that would with this.  thanks.
bigcarl5000kg
HI @russel,
in general, you can find an incredible amount of information on the Internet and in Youtube ... of course also in Advance Steel Help.
https://help.autodesk.com/view/ADSTPR/2025/ENU/
If you can, I recommend a basic and then an advanced course for Advance Steel, you just need to find a supplier (eg. Graitec) not only in your area (courses are often run online as well).
As an absolute self-taught person, it will be very difficult for you, even though it is CAD based on AutoCAD.
I the attachment you will find some little bit older but still amazing basic guides.
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
bigcarl5000kg
BUT ... you should also know that Advance Steel is since 03/2023 in maintenance mode, no further development will continue. Here in the forum you will find a lot of informations about this.
