Monowills Stancion Issue
SMPConsulting
Message 1 of 16
SMPConsulting
Hi AS community,
I'm getting 2 clashes I can't seem to clear when modelling Monowills Stanchions.
The first one is the bolt with the stancion, for some reason it is inserting a bolt for 90mm so this could be the issue but I can't seem to find a way to adjust the length and clear the clash.
The second one is with the angle of the hole in the spheres for the hand and kneerail, for some reason they are not rotating to align and match the angle of the stair. I have attached an image.
Is @Anonymous online as I believe he wrote this macro for the Australian AS version.
Anthony Paul
www.smpconsulting.com.au
An Inventor user since IV6 2002, and a 3D AutoCad user since R9 1989
i7 7770 @ 3.6GHz – 4.2, GB H110M M.2 Mainboard, 2 x 8 GB DDR4 RAM
250 GB SSD 960 Evo Series SSD, 700 W 80+ ATX Power Supply, Win 10 Home 64 Bit
Replies (15)
Message 2 of 16
iwafb
Hi Antony,
What angle is your stair? And also, did you select beams from bottom to top?
Maybe if you could attached the model?
Message 3 of 16
SMPConsulting
Hi awfb, mate thanks for your response, yeah the stairs are 45 degrees and yes picked the system line from bottom to top. I updated the stancion block moving the tube down further on the base plate to give the top bolt more clearance and then I inverted the bolt and presto it shortened up and fixed the clash.
I then rotoated the spheres 45 degrees and that also fixed that clash.
I seem to remember discussing this with Stephan Gumbert a couple of years ago and he gave me that solution (edit the stanchion block), but I seem to remember he was working on an update.
Are you from Australia? do you use the momowills macro yourself and if so how do you fix the issues like I have been experiencing??
Anthony Paul
Message 4 of 16
iwafb
Hey Anthony,
Yep, based in Australia.
In short, we've started using the Monowills macro quite heavily recently. Not sure if you're on AS2021, but get on if you're not...😁
There have been a lot of bug fixes in 2021 and we recently completed a project with around 300 handrail assemblies and I only had to explode one macro and apply the workarounds. Having said that, there is a minor bug in that the holes in the kick plate bracket and base plate are not fully drilled through the post, so the bolts will give you a clash, but it's a vast improvement on the previous versions.
I can see from your image that it looks like the post base plate is offset the wrong way, so I guessed 45 degrees. One tip to avoid this problem is to change the "AngleMax" value in the AM post offsets to 45.1
Hope it helps
Message 5 of 16
stephan.gumpert
Two things here.
The holes in the stanchion was an existing bug, depending on the version of use this has been resolved.
Also important to notice Monowills stanchions are designed up to 45 degrees, with a certain degree stairs the bolt head starts to hit the post.  What is the angle of the stairs? (Angle should be in the post)
As a tip, With stairs always model them from bottom to the top of the sairs.
Message 6 of 16
SMPConsulting
Thanks for the feedback @stephan.gumpert
I am using AS 2020, are there any bugs in Monowills macro for this version?
The stairs are 45 degs which is compliant with AS/NZS 1657.
Below is an extract from the Monowills tech data regarding base plate hole set-outs and I think the issue with the macro is with the model of the stanchion being used not complying with the monowills dimensions for a 45 degree stairway.
Stephan any feedback you can provide would be gratefully appreciated as we use the Monowills system almost exclusively.
Anthony Paul
Message 7 of 16
stephan.gumpert
Try to modify this table & field to allow for just above 45 degrees.  The formula is a Less than function.
Message 8 of 16
SMPConsulting
Thanks for that feedback @stephan.gumpert,
So I have updated that rule to 45.1 and it has fixed the bolts but the stanchion is now still unchanged.
Is this because I'm on 2020??
Do you have to update the rule, AND amend the stanchion in the block editor as well?
Anthony Paul
Message 9 of 16
stephan.gumpert
Sorry should of mentioned this.
Once  a block is created the definition is never changed once created.
So after changing the Table value, you will need to:
  1. Reload the Database
  2. Delete that type of block from drawing
  3. recreate te handrail
Once a block definition exists the system just uses the current definition.
Message 10 of 16
SMPConsulting
Thank you @stephan.gumpert , as always your help is very much appreciated.
Anthony Paul
Message 11 of 16
SMPConsulting
Sorry to bother you again @stephan.gumpert , however I'm still not getting the right sphere rotation to suit the stairs.
I trialled macro in a new DWG file so there were no existing blocks.
How do you re load the database? I have never done that before? How is that done? Is that the problem?
Anthony Paul
Message 12 of 16
stephan.gumpert
That is a known bug.
Message 13 of 16
SMPConsulting
@stephan.gumpert  can you fix it in a file by replacing the block with a modified block/stanchion?
Anthony Paul
Message 14 of 16
stephan.gumpert
Yes, the workaround is to use the blockeditor and change the hole through the sphere accordingly.
Because the blocks only get created once this works very well.
Message 15 of 16
SMPConsulting
Hey here's another Monowills question for your Stephan @stephan.gumpert ,
I'm now using AS 2019 but still getting clashes with Monowills handrails.
Also is it possible to model curved/rolled guardrails with the Monowills macro?
Anthony Paul
Message 16 of 16
stephan.gumpert
Curved beams are currently not supported.
